receptacle above ceiling
For most anything, you just can't leave a flexible cord plugged into it.
Roger
If the power supplies plug directly into the receptacle there is no problem, if they have flexible cords on their supply side there is a problem.
Roger
I have not specifically looked this one up but there is several instances that must be acceptable as "Sensormatic" theft prevention CPU's are always allowed as are FAU's with a cord connection. The problem is when you have utilization equipment below the ceiling that might have the cord pass through the ceiling such as scenting systems, camera power supplies or television monitors which are certainly a hazard as they cannot be readily disconnected without entering the ceiling space.
I can't count the number of times that a customer wanted TV displays installed with cord and cable routed into a rec installed above the ceiling. Especially large retail outlets with national engineers drawing the illegal detail on their plans. They just don't understand when I tell them NO. http://forums.mikeholt.com/images/icons/icon12.gif
