Got a call to a house that recently had foam insulation installed in the exterior walls via drilled holes from the outside. Product was shot into the stud cavities, it expands somewhat, then dries. Before the work was even completed a circuit breaker tripped and power was lost to 2 rooms.The installer removes a recep from a box in one of the walls in question and finds that the foam has penetrated into the box(all boxes metal and grounded) he removes it and puts the recep back in. Breaker is reset and stays on for several hours then trips. I arrive 3 days later and the homeowner and I go to the panel , he attempts to reset it twice and it fails, I reset it and it holds. As I'm looking around one of the rooms in question it trips, reset's instantly and stays on for about 30 seconds and trips again. Again I reset it and put a meter on it and it's drawing about 1 amp(ceiling fixture in 1 room is on)we B/S for about 5 minutes and it trips again. Any clues at all, I can come up with several reasons if it would act consistently, but the randomness has got me scratching my head. Thanks.
