electric stove
nafis
Palestine,tx
Hi Guys,
I am looking to purchase an electric stove for a customer of mine. He wants to install in a
guest house which has a sub panel 30 amps single barker in the entire guest house. Is
there any stove that works on a 120 volt with minimum amp, if so where I can purchase it.
Thanks
Nafis
augie47
Tennessee
I think there are some "Barbie" stoves that work with a 100 watt lamp :grin:
the menu might be a bit more limited than your customer desires.
Cold Fusion
way north
... Is there any stove that works on a 120 volt with minimum amp, if so where I can purchase it. ...
As brad suggested, apartment sized (24") gas stove with an outside propane bottle. That's what I put in my cabin. Works great. I could get it with either a plug-in electric ignitor or a piezo(sp) ignitor.
I'm assuming you don't want a two burner hot plate and a microwave.
cf
JFletcher
Williamsburg, VA
A one or two burner hot plate is about all you can run for an "electric stove" on a 120V service with such little capacity.
