puckman
- ridgewood, n.j.
Maybe someone can explain how this works. I have a pv system where i work its output rating is 125amps at 480volts. The control box where all the cables enter is located outside and locked up so i could not look inside. It has a 150a 3 phase 480 volt line coming from our 600amp mcc that is feed from a switchgear room in another building. Also it has the dc lines coming from the roof to a trough that has two Sunny combine boxes nippled on it, the dc line go into the control box. also a 3/4 line going inside to a wireless box with an antenna attach to communicate with other panels else where in plant.
The control box out side has a panel meter reading unit output is 85 kw when air conditioner inside box is on and when it goes off meter reads 25kw. I hear about power going back into the grid, i just don't see how it happens here and why the 150amp line from the mcc. I don't see any other lines from the control box and there are no batteries. What am i missing and don't understand.
