My first pic here.
In a semi-quasi-kinda-sorta related way, today on Ask This Old House, they showed an electrician cutting the energized service drop at the POA and using a rubber cord to supply a power distribution module.
He was using bare aluminum set-screw-type butt splices to attach 3 wires of the 4-wire rubber cord, the other end of which had a female cord cap which plugged into an inlet on the power distribution module.
No OCP, no EGC (as far as I could tell), no metering, and only a layer of tape on the splices. Also, no protection at all, using blue-handled Kleins and a metal Allen-wrench set, and perched on a fiberglass ladder.
Now that I think about it, this might be a better post for one of the current working-it-while-it's-energized threads.
Improper strapping.
Not that I'm aware of, just 110.12:D
Let's assume the cable was supported properly.
It has been stated here many times that since 'neat and workmanlike' are subjective terms, 110.12 is nearly unenforceable. The FPN lends some assistance in referring us to ANSI/NECA 1-2000. (In the 05 NEC, our cycle). ANSI/NECA 1-2006 is available now. It is 30 bucks for a 615k pdf.
I read on another forum some sage advice. "Bad workmanship is like pornography. You will know it when you see it."
Has anyone here bought the ANSI publication? Was it worth the 30 bucks?
SE is rarely done right after re-siding. Wrapping around meters is another of my pet peeves.
I too find it hard to see a violation, to us "southerners" the whole thing is just wrong. Where is the RGC or PVC riser? :)
Interesting thought: Why is it that we guys who are permitted to use SE for service risers don't insist that everyone else use it, but electricians who use must or opt to use pipe do feel compelled to insist that everyone else should? :confused:
