I believe that rating is per socket, not an overall fixture rating. Otherwise, it would say "max total 120w" or somesuch.
For example, I don't think you could use a 75w and a 40w and still be within the manufacturer's rated limit.
It had porcelain sockets, so I would assume they have the standard 250V/660W rating alone.
I installed a passel of these fixtures today, and I was asked (hypothetically) if installing a single 100w lamp would be 'legal'.
That may be true, but the fixtures obviously cannot take 660w bulbs, so that's not what it's based on. It's the fixture assembly as a whole.It had porcelain sockets, so I would assume they have the standard 250V/660W rating alone.
I stand by my answer: no.I installed a passel of these fixtures today, and I was asked (hypothetically) if installing a single 100w lamp would be 'legal'.
How about using CFL's? You can use the actual wattage for the fixture rating, which is about 1/4 of the equivalent light output.
Don't forget a burn-in period.
There's a thread in the NEC forum you might be interested in, labeled "charcoalized wood."
Isn't that what I said?I would say it would go by the actual watts used by the CFl since this would be the bases of the heat produced?
Isn't that what I said?![]()
Not to mention sped typing.Yea yea, I know, no more sped reading for me:roll:
Not to mention sped typing.![]()
Yeah, they're pretty quick around here.Oh you don't have to worry about that, by the time I answer a post, theres 4 replies to it already:roll:
The restriction of wattage for incandescent is based upon the heat produced by the lamp, CFL's come no where close to producing this kind of heat, so I would not think the same limitations would apply. in fact we use recessed rated 26w CFL's in shower trims to get more light out of them with out the temperature limit tripping. I would say it would go by the actual watts used by the CFl since this would be the bases of the heat produced?
This is/was EXACTLY the question I came on here today to ask. It came up today on a job. I always tell customers they can use CFL's and for the most part, ignore the ratings on the fixture( when usind cfl's), which I too have always believed were for incandescent bulbs only. It never dawned on me to add up the wattages consumed by the CFL's. Two 60w equiv cfl's are def brighter than two 60w bulbs .
Aren't you the same guy?I would say yes the wire and socket are rated for it go 120w in one.
