gfci with non gfi
i always though it was an issue and remember seeing some in the nec maybe not exactly forbidden but not a good practice
Its completly acceptable. Just as long as the line and load neutral are seperate - otherwise the GFCI will not work correctly.
The only wires to be kept apart are service conductors and feeders / branch circuits. [for residential]
~Matt
The only instance I can think this may be an issue is if the line side is the service entrance conductors, and the load side is GFI protected.
I don't think there's too many instances of this happening.
680.23(F) has such restrictions on circuits for pool lighting.
