In my home I have a couple of lighted 3-way switches and a lighted four way controling 8 lighting outlets (no dimmers). Four are reccessed cans and four are sconces. The sconces each have two candalabra bases. I decided to replace my compact flourescent lamps, working fine for a few years or so, with new LED types. When I changed the lamps in the sconces two things happened: when the switches were on everything was fine. When the switches were off the largest compact flourescent lamp will dimmly alternate on and off and the LED lamps were lighting dimly steady. Also when the switches are off they are not lighting like they should. There was no warning on the lamp package regarding use with lighted switches; which is were I'm guessing the issue is. Question one: It is the lighted switches causing the problem, right? Has anyone else seen this? And question two: is it a fire hazard? The LED bulbs seem to have a PC board or something like a ballast at the base.
Thanks. I Love this forum.
