schererguy
Im using a portable mixing vessel in a Class 1 Div 2 location with SO cord and
Killark plug.
The xp motor has thermal switches connected in series inside the motor case.
Is it necessary to use these thermal switches on portable equipment?
Are there any Class 1 Div 2 plugs and outlets that have extra contacts for the thermal switches?
There is an inverter installed outside the room that controls the motor speed,
is it proper to use the thermal switches to disable the inverter when the motor reaches its high temperature or do I have to install a contactor between the motor and inverter because the inverter will hold a charge even after it is no longer enabled?
Killark plug.
