Va calculation for receptacle
gmtt
For load caluclations, do you use 180va for each duplex receptable or 360va? Similary, for quad receptacles is it 180,360 or 720va for each quads? I used 360va for each duplex and 720va for each quad.
180 VA is the standard for each mounting strap. So, a duplex outlet is the same as a single outlet.
"Quads" would count as 2 straps, or 360 VA.
I believe the Code uses the term yoke in this instance. 220.14(I)
