FrancisDoody
- Durham, CT
Have a job requirement to wire R.A.B. model STL-110 motion detectors in parallel. Is this possible and will it be reliable. Thanks.
Not sure what you want to do but I have wired two standard motion detectors that control one set of lights. Basically you feed one motion and then run a 3 wire to the 2nd motion. From there go to your lights (Load). It is the same as you would wire a 3 way switch to some degree. Feed your black wire of the 3 wire cable and energize both smokes then the reds get connected together and tied to the load.Have a job requirement to wire R.A.B. model STL-110 motion detectors in parallel. Is this possible and will it be reliable. Thanks.
Does this help
we have done this on long driveways nto control the lights along the driveway from either end
Does this help
I meant motion detectors. Power both units with the black and feed the red thu to the load connecting both red wires together of the motion detectorsWhat do you mean by ENERGIZE BOTH SMOKES? Why did you say SMOKES?
ok! makes sence, but are those motion sensors capable of handling that much of a load?
If not, have them activate a contactor.ok! makes sence, but are those motion sensors capable of handling that much of a load?
