ohmhead
- ORLANDO FLA
Well question ? Vfd distance from drive to motor cable length ?
What is the rule of thumb is there one ?
Different lengths for different manufactures no one is the same ?
We know its better to be near a motor and most say use a filter or line conditioner to help with harmonics and PWM voltage spikes but give me your input to the most effective ways of installing a vfd at a distance from motor i like to hear what you think ?
I read three grounds in a conduit wrapped in a spiral twisting method of a three phase motor circuit hooked to a VFD improve long length harmonics effects & voltage peaks as voltage can get near twice the normal level of input voltage due to impedance of the wire to the motor due to distance between drive and motor .
What your thoughts?
What your thoughts?
