I just failed the WAC/RCW portion of my Administrator exam & I have some questions. First there was this question. Once a violaton of WAC/RCW judgement is ruled final by the Board, violations within ______year(s) are considered a addition violation.
1
2
3
4
I might wonder how you came across that little factoid. Your profile's zip code puts you on the other side of the country.I will tell you it's in WAC 296-46B-XXX.
I'm Not surprised!!By the way, I took a look at the L&I web site, and was able to find the answer within one minute.
I might wonder how you came across that little factoid. Your profile's zip code puts you on the other side of the country.:grin:
I passed the rest no problem. I thought the Calculations was the easy part. I'm just having a hard time with the WAC/RCW portion.
I found it pretty easy too. The answer is 'within 3 years'. I couldnt help it, Just had to give the answer. Section WAC 296-46B-915
Maybe someday but I still need to get my 01 or 02 Journeyman. I think having the 01 Admin + the hours I have would make me have a better chance of getting a job with a good company over some other apprentice's even if they dont need a administrator.
Charles,
In theory that works, but in reality, the Journeyman Electrician's in the field need the supervision of a Master Electrician. This how it is set up in most States. In many cases, the Journeyman in the field need additional tech support when installing a job. Unless they are veteran Journeyman who have the skills of a Master, just to lazy to take the exam....
