Strahan
- Watsontown, PA
Not sure if this is the correct place for the thread or not but here we go. I don't have much time.
Asked this question single phase well pump. No controller 240vac being turned on and off with pressure switch which is fed from a breaker. One leg is pulling 9amps next leg is pulling 12amps and current flow on neutral is 4amps. Obviously something is not balanced I suggested checking all connections. Motor came prewired. Also was told the breaker has tripped and been reset multiple times from old motor. I suggested checking breaker any ideas?
