New insulation tester
sparky_magoo
Reno
I am finally ready to buy an insulation tester. I am considering the Fluke 1507 and the Megger MIT230.
Any thoughts about which one is superior? Or should I consider something completely different?
Well its a good tester
We use it every job its tuff and the batterys last for a good 2 weeks and thats if you test 8 hours a day .
I use the Fluke 1587.
It is an insulation tester and multi meter combined.
Saves carrying around both.
I have a Fluke 87V and am happy with it. I don't need another multimeter or the added expense.
I had the original 87 and the display finally failed. Fluke couldn't fix it, so I had to buy a new one.
Than go with the 1507. Are you just going to use the IR tester for initial acceptance or maintenance as well???
I plan to use it for initial acceptance in the future. There isn't much commercial work in Reno right now.
I have never had a need for using an IR tester for maintenance records.
It will primarilly be used for testing suspect conductors and cables. At the moment, I want it for testing underground 25 pairs which have been causing problems since thr recent storm.
