macmikeman
- Planet macmikeman
And I have my own little opinion about it all. We learn how many nm conductors can go in the hole before we start de-rating. We can translate that to the number of cables. It is all scientifically done via simple calculations, except the whole concept of the number of cables passing thru a hole drilled in a 1-1/2" wide wood member causing overheating problems is pure speculation in the first place. Especially when you have 16" of air space to bleed heat off before they go thru the next hole. And the holes could be 2"" diameter with 5- 14-2 cables and by the way we currently interpret the code, this would be a fire hazard, except it is not one in reality.... If anything there should be some added language regarding fill volume of the holes, so at least a larger hole with a few more than 4 cables would still be doable, without de-rating, as long as it did not go over a certain volume fill.
