Don't apologize,I realy apreciate any inputs and you gave me great exampleDerick -
You didn't give us any clues as to where you need help. So I start this pretty simple - but I suspect you already know all of this.
The secrets are in the tables notes.
(discussion is limited to US units, copper conductors)
T8 gives the direct current resistance per 1000 feet and 75C.
So if you wanted to know the DC resistance (at 75C) of a #6 wire, 350 foot long circuit
R =((350 x 2)/1000) x 1.608
The "x 2" is because the circuit is 350 feet out and 350 feet back - total conductor length is 700feet
The "/1000" is because the table gives resistances in ohms/1000feet, not "ohms/foot". So dividing by 1000 gets the units right.
And 1.608 is the ohms per 1000 feet for #6
Table 8 also gives the formula for the resistance change with temperature. See note 2.
Note on DC resistance:
For resistive loads, power factor = 1, stuff like heaters, incandesant lights, the DC resistance is effectively the same as the 60hz AC resistance.
I appoligize if this is too simple. As I said, I suspect you already know this.
cf
No, T8 is bare conductors. For couduit fill you would want to use T5...By your example I see it can be used to find the size of the conduit if conductors of different sizes to be placed in the same raceway as well. ...
Excellent job. You passed your test and caught the error:roll: (laughing at me)...Couple things looking at your formula you ment to X 0.491 instead of 1.608. 1.608 is for ohm/km and 0.491 will give us units in feet in K. ...
T8 is all about bare wires. I THINK coated is the tinned wire one sees occasionally. I THINK with the tin coating, the copper diameter is a bit smaller so that the diameter with the tin coating is the same as the diameter with out the tin. Copper is lower resistance that the tin, so the tinned wires are a bit higher resistance....Another question I had:What is the meaning of Uncoated and coated. ...
Yes,thank you got it nowNo, T8 is bare conductors. For couduit fill you would want to use T5
cf
i have a question about nuetrals, i have a commerical building that the nuetral has the same amp readings as the hot when applicances are on. is that normal? a dedicated circuit was ran with nothing else on it and it has the same reading. i aplogize if i did not post this right or in the right forum.any help on both issues with be greatly appricated. thank you
