I was working in a residential panel installing a surge protector; while terminating the grounding conductor I decided to move another grounding conductor to another higher terminal to maintain a neat appearance and to keep the wires from the surge protector as short as possible (as specified in the surge protectors instructions). As I disconnected the EGC that I wanted to move, I wound up getting shocked (I was holding the bare conductor in between my thumb and forefinger and my forearm on my opposite arm came in contact with the panel frame). After deenergizing the panel I traced that offending bare copper EGC back to a 6/2 nm cable feeding a GE induction cooktop. I cleared the bare copper EGC from all wires and metal and reenergized the panel. A test between the EGC and the neutral/ground buss gave 110 volts. I figured a neutral was tied into the ground from the cooktop since it was a 6/2 feed. Checking the junction box at the cooktop revealed only two hots and a green insulated ground. Everything seemed fine on the branch ckt: no over driven staples, over tightened connectors, good splices at the junction box. I reconnected the EGC at the panel, and opened the splice at the junction box. Once again 110 volts between the appliance ground and the ground from the panel. Just to be sure, I removed the EGC from the neutral/ground buss again and tested between the EGC and ground; with the branch EGC still disconnected from the appliance ground I got 0 volts which means the issue is at the appliance not on the branch wiring. Testing between the appliance ground and the hot wires resulted in: 230 volts to black and 11.4 volts to red. I was wondering maybe one of the induction coils might be grounded somewhere, but the weird thing is that the appliance works fine and I did not detect any significant leakage current on the ground with my amp probe (but I do not think it would pick up anything in the milliamp range). The only other thing I could think of is maybe there is a low voltage application for the control pad or indicator lights that might require a neutral but it seems unlikely that GE would miss something like that. I looked at the service manual and It gave no indication of a transformer anywhere in the cook top. GE technical support was not helpful as they had no electrical knowledge whatsoever. I eventually pestered a consumer relations rep into giving me an actual GE tech support number for GE techs. The technical rep was skittish about talking to me because I did not have an account with them but I managed to beg a minute of his time. After hearing my story his only response was why I was working live? I admitted that my failure to follow proper electrical safety procedures was regrettable, but not quite the point of my call. He recommended I have the home owners call for service but admitted a tech would most likely see that it was working properly take off.
Has any body heard anything similar, have any idea what the problem might be, or know what my next step might be?
I was wondering if it would be possible for the cooktop to operate properly if one of the induction coils was grounded or if there would be enough leakage current detect. Unfortunately I did not have enough time to do a lot of testing and I really don?t think it would be wise for me to start taking apart an expensive new cooktop since I?m not experienced in appliance repair.
thanks
brian
thanks
brian
