Sq ft basic understanding on biding
I got offer to bid a job in south of san francisco. SQ FT is 2670 I bid the job for 7440.56 and Im waiting for his response? What you guys think? Am I too Low-Middle or High?
Well,
I just landed a 2500 sqft job in Greenville, SC for $8000. It includes the cans (I bought several cases of Halo on clearance for $2.00 a can), wire, and service. There is a $2000 allowance for fixtures and trim. Less than what I would normally do it for, but it is only 5 houses down from mine. It is a spec. remodel, and I did wire the owner of the properties personal house.
It will be a 200 amp service, wired mostly in 14. It is $3.20 a foot. Plus, I get to walk to work. Not sure what rates are in CA, but you might be a bit low.
c2500
finish trim was 2,955.56 with switches, receptacles gfci receptacles, (dimmers & occupancy sensors title 24 CA) lutron, wattstopper and decorator pass & seymour
I have to confess that I don't get the price/ft thing at all unless your doing track work. We just bid a 2600 ft house for $19,650 and were in the middle of the pack. When you have a custom home the price can be all over the board. You can have a pretty accurate number for wiring a home to minimum code, but it all changes when you start doing LED lighting, spas, steam showers, baseboard lighting, yada, yada.
well its been a while since I had to bid but when I was doing house's in VT it was 6 to 8% of total job, 4.00 to 6.50 sq ft, or 55 to 65 a hole. Everything above 120V was figured seperately, cans, smoke detectors/ 3 ways, 4 ways, gfi were bumped up, Dimmers, motion lts outside
Your bidding at 2.70 sq ft way to low.
Whats the sq ft of a new house these days, no fancies $135 to 165 maybe, I don't really know
Wired in 12-2 NO 14-2
2670 X 135 = $360,450
2670 X 5.50= 14,685 then you add lt package ($2000, C2500 price), cans, ceiling fans, electric range, dryer, misc adds by wife of customer.
14685 + 2000 + 600 for cans + 125 for dryer + 145 for range + 1000 for (8)smoke detectors and 1 co detectors $125, 2 motions RAB 1000 2 heads each $300, I,m sure I'm missing something.
total $18,980
6% of 360,450 = 21627
ok off by $2647
If some one could give me prices on wire, devices ie: sw, gfi, and boxes, I could come up with a price per hole.
this worked for me and I was working steady
OK TIME FOR THE BEAT DOWN:D
