jumper
- 3 Hr 2 Min from Winged Horses
Personaly, I just like to sleep on my remote:
Exactly. The ribbon is long enough to split it to route the emitters to a single or double stack of equipment, and doesn't allow the possibility of mis-wiring them.The Hot-link though has a few draw backs visible right of the bat - just from looking at it...
But I guess it is just a black box leaving the mystery intact of it's operation to the uninitiated....
- The eye, and ribbon cable for the emitters look proprietary.
- The cables are fixed lengths...
It also doesn't look like you can replace them if one goes bad, or add one if what is there is not enough down the line... Since most are 1/8" jacks (on 2'-6' cable), it is pretty easy to replace one on other systems, and the eye is in a termination block so the wire can be fished easily... The reciever cable on two of mine is like ~50' long (18/4 thermostat wire)... That one looks like a fixed length of 5-6 feet???Exactly. The ribbon is long enough to split it to route the emitters to a single or double stack of equipment, and doesn't allow the possibility of mis-wiring them.
It says 7ft, which would still allow almost a 14ft spread. It is designed as a simple, foolproof, all-in-one system, and six emmiters are plenty for the typcial home system; it's enough for mine, not including the projector.It also doesn't look like you can replace them if one goes bad, or add one if what is there is not enough down the line... Since most are 1/8" jacks (on 2'-6' cable), it is pretty easy to replace one on other systems, and the eye is in a termination block so the wire can be fished easily... The reciever cable on two of mine is like ~50' long (18/4 thermostat wire)... That one looks like a fixed length of 5-6 feet???
The answer here is yes... the repeater is separate and acts alone with any remote - just repeats whatever comes it's way.
Where as Niles and Russound, as well as a few other generic brands are compatible with each other in terms of expansion and availability...
Yes to all. The repeater emitters self-stick over the IR receiver of each component, and are clear enough that the IR will also pass through them with the Hot Link powered off. The repeater does just that: it duplicates whatever IR signal the receiver picks up.
Don't underestimate the Harmony. To watch a DVD, for example, you press "watch DVD" and it transmits whatever it needs to in order to select power on/off, input, etc., for each component. It has what's known as a high WAF (Wife Acceptance Factor).
It's as easy to program as making a list of the make and model number of each component, going to the Harmony website and creating a profile, inputting the equipment list, answering a few questions, and uploading the completed programming to the remote.
So talk to me, I have maybe 5 items to control in my living room and would like a simple to use all in one remote. Whats good?
I'm not convinced. I bought a Harmony 610 about six months ago, and it seems to work fantastic for about four days and then started to forget things. For example, when I watch a DVD I need the remote to tell the TV to turn to Channel 4, and then turn the DVD player on. Usually, I wind up turning it to Channel 4 myself, since it has forgotten.Harmony, baby, and you don't even need one of the top'o'the line models.
The Help button doesn't even know to ask if it's on Channel 4, so I think I need to do what my parents did - have a kid change the channel for me. The Harmony remote I have has not caught up with Biology, yet.![]()
And is exactly why I don't volunteer anything for the remote. Better to let them try on their own, than try to be a superman and provide a faulty whiz-bang solution that I can't control, to their problem.That's what scares me about providing the remote and the programming.
This too is also my only real problem with the harmony remotes - the "help" button can sometimes "Hurt" by screwing up a good macro. And initially the programing of all the macros is done by answering some questions on a web-site - sometimes what you want to - or need to do, is not in one of the questions - it gets missed, and you have a glitch going to point A to C when A to B to C was fine.... You can go back to the web-site and fix this if you ansewer or ask the right questions...I'm not convinced. I bought a Harmony 610 about six months ago, and it seems to work fantastic for about four days and then started to forget things. For example, when I watch a DVD I need the remote to tell the TV to turn to Channel 4, and then turn the DVD player on. Usually, I wind up turning it to Channel 4 myself, since it has forgotten.
I wouldn't, because any signal delay will result in multiple signals that might get misread.I am wondering though should I connect the TV to the repeater if it is already exposed?
I'm very suprised you're not using an AV input on the TV. The tuner (RF) input provides the worst signal quality.For example, when I watch a DVD I need the remote to tell the TV to turn to Channel 4, and then turn the DVD player on. Usually, I wind up turning it to Channel 4 myself, since it has forgotten.
It shouldn't. Using the Help doesn't change any programming, it just re-syncs the actual component on/off states with what the remote thinks they should be.This too is also my only real problem with the harmony remotes - the "help" button can sometimes "Hurt" by screwing up a good macro.
That reminds me of the Memorex CP-8, which was one of the first macro remotes. I had to invent a few tricks because the 'on' and 'off' commands are the same on most components.The alternative is to get remote with a good number of manually programable macros... Which can be a learning curve - you need to know what each button of each remote "REALLY" does and plan out paths between the functions you want... Old-school...
I'm very surprised you're not using an AV input on the TV. The tuner (RF) input provides the worst signal quality.
Well, I had the surround sound DVD player on HDMI before it died prematurely (which is the result of my crusade against Phillips). I think my DVD player now doesn't have an input on it that the tv will use and still produce sound, but I have long since gotten tired of fiddling with it.
The picture and sound quality isn't half bad, even with the crummy rf converter.![]()
Fly me out there, and I'll hook you up!... I have long since gotten tired of fiddling with it.
Ouch!That means it's only half good.![]()
It can change the macro - by you telling it that the macro did not work - it will change an option or two... e.g. Like assuming the TV is always on channel 4 when you might change it at another time.... It would delete the number signal for 4... There are a few options given to the remote to be presented in the help mode... An alternative is to go to advanced programming and create your own macro (I had to) - but I don't know if that is available on all models...It shouldn't. Using the Help doesn't change any programming, it just re-syncs the actual component on/off states with what the remote thinks they should be.
