ohmhead
- ORLANDO FLA
Well NO it only moves its atomic structure of charge to opposite plates of what it had to begin with .
Nothing added only a force to equal the attraction and repelling of each side of opposite plates .
Its kinda like the battery people think specific gravity is electrons but its the solution in the battery which has weight not electrons when its charged the electrolyte is heavy due to absorption of positive & negative qualities.
Then in the discharged state the charged acid in the pores of the plates that were attached separate into the mix a back and forth move then we only are changing the weight of the solution by charge and discharge of plates absorb acid in plates and then specific gravity of electrolyte decreases or increases .
Were not adding weight were transfering mass from one point to the other by a charge internally .
