I think I have a pretty straight forward question here. I am running parallel 4/0 URD conductors over 400' underground to a meter w/ disconnect 200 amps. For my grounding conductor do I size it based on the size of the two 4/0 conductors which looks like it would be a 1/0 grounding conductor. Or is the grounding conductor based on 200 amps? I'm looking at table 250.122 which is stating the overcurrent device should be before the conductors. Before the conductors in this run is the utility transformer.
Thanks- I do mostly small resi work, haven't had to do much with large parallel conductors.
