Last night at work my partner and I were replacing the bearings on a 3ph 480Volt motor. After we got done we decided to test it. Out of curiosity we decided to put an amp clamp to measure the current. Another guy come along and asked "what would it read it you put T1 and T2 in the clamp?". I told him that it would read 0 because they would cancel each other out being that they are 180 degrees out of phase. So I did it to show him and suprising to me the meter said 3.62A.(on T1 and T2).......When I measured T1 by itself it was 3.59A. When I measured T2 it was 3.6A and when I measured T3 by itself it was 3.62A. SO.....I went back and clamped T2 and
T3 (together) It read 3.59A.. then I clamped T1 and T3 it read 3.6. ..So I come the assumption that when measuring 2 phases together it will give you the 3rd phase current....Is this true? If so I think its because the 2 phases are canceling each other out and your reading the current on the 3rd phase comming back through the motor windings. Does this make sense to anyone?my theory true? Please let me know because this is somehing that was never covered in college.
