brantmacga
Señor Member
- Georgia
- Former Child
............You send the plans, and they pre-fab all of the branch circuits for you.........
I would much rather design my own system and order what I know I need.
Also, what happens betwixt ordering the stuff and trim-out when the HO changes a dozen items? Kinda puts a wrench into the gears.
so it seems leviton has purchased cheetah speed systems, which i have seen before, but they have another company they purchased i have not seen; EZE-Rough.
take a look here.
If you think that will really work, I've got some oceanfront property in Arizonia.........
EZE-Rough Website said:With over 14,000 unit installations, the EZE-Rough System has proven to be the simplest and most cost effective solution . . . .
Of course this can work and will work in some applications. If everybody was unwilling to try new things we'd still be soldering connections on knob and tube wiring. Loosen up guys, it's ok to try something new once in a while. :roll:
We tried it and was not able to use 50% of it on one job.
Unless you have all the trades in tune, it does not work.
There is always a plumber or A/C man who puts stuff in your way that causes you to add to the scrap pile.
I do not recommend it at all as we tried it and it failed.
