This week I am going to have to install some IP security cameras in our facility.  I've been putting this off for some time now, but it's time to bite the bullet.  The camera mounts in a thermoplastic housing which is temperature controlled and has a metal base.  There is a a circuit board mounted inside the housing which requires 24 VAC, 25 watts max.  The camera is then fed from this circuit board and requires 4 watts max.
I have 120 VAC available and am going to mount a transformer in a continous hinge enclosure in the IT room and feed each camera through it's own EMT from there. I am going to bring an Ethernet cable into the enclosure and connect it to a switch in order to branch out to each camera seperately, in effect making this a main control panel for all of the cameras.
I have 2 questions:
1: Each camera will be individually fused on the secondary side of the transformer. Can I put a 30mm key switch in the circuit for each camera, between the fuse and camera, so that each can be serviced without disruption of the others?
2: Is there anything prohibiting me from running the Ethernet cable in the pipe with the 24 volt circuit? Each housing will be grounded back to the control panel.
I have 2 questions:
