You have to get that information from the design engineer.What is the hazardous locaction boundary at an active solid waste landfill? For example, 'x' feet above grade, 'x' feet from actual dumping area, 'x' feet from leachate pipe venting. Where can I find this info?
Thanks!
It would appear that Jeff is the design engineer. I am unaware of any reference document that directly addresses his question. I'd have had some initial "lack of experience" issues myself. However, I believe I can suggest a reasonable approach.You have to get that information from the design engineer.
I guess I should look at the profiles before I respond.It would appear that Jeff is the design engineer. ...
