compression termination for large wire
Electron_Sam78
Palm Bay, FL
Does anyone know of a compression termination for large wire that will reduce the size of a wire for termination? For example I have a 4/0 Aluminum wire that I need to terminate at a 100a GE THQB CB
Both insuleater connectors and polaris will do what you want. Maybe you will need to add a splicebox so you do not exceed box fill in the panel, but that is another story
Thanks for the links. I'm actually looking for a reducer that would take my 4/0 stranded down to a solid pin the size of a 1/0 conductor
You need at look at page 20 of Connectors from this pamplet.
NSI as posted eariler.
Accordingly 4/0 only goes down to 2/0...
