jango
I have a scenario where we installed a 4" PVC service lateral sweep into concrete to accomodate a 200A electrical service panel. Now the panel has been upgraded to a 400A service and the 4" PVC pipe is no longer in line with the knockout on the 400A panel below the meter. My hope is to heat a short length (3' or so) of a piece of 4" PVC in an approved PVC heat oven to give it the necessary offset to line up with the knockout of the 400A service panel. Are there any other suggestions on how to achieve this or should this method be ok. Also, would this be a call made by PG&E or the local Building Dept.? The good thing is that there will be a pull point in-ground box not too far away from the building. Any suggestions and/or feedback would be very helpful.
