flashlight
- NY, NY
- Electrician, semi-retired
We are wiring a commercial kitchen which has free-standing reach-in refrigerators in the middle of it, about 6x3 ft. footprint, 2 of them.
They will have a work surface on top, so we need to provide outlets for
that (slicers, blenders etc.) plus the units themselves.
A floor poke-through is impossible, so we are dropping power from the grid ceiling above.
We will come down through the ceiling with rigid conduit supported by strut.
A couple questions came up--
Can we have GFCI receptacles mounted in boxes above the ceiling, feeding the receptacles below? The customer thinks it's an easier reset than way down to the basement for GFCI breakers. GFCI receptacles at the point of use would not survive.
Also, the chef wanted retractable cords above the work surface. From my research, I didn't find any hardwired units. So we would provide the GFCI protected receptacle at the ceiling, and they would provide the retractable cord assembly. The GC says just to use laundry drops, about 2 ft. off the work surface.
Any thoughts on code/practical issues here would be appreciated.
