- Illinois
- retired electrician
Many utilities size the primary fuse to protect only the primary distribution system. In these cases it will be unlikely that the primary fuse will open for any type of fault on the secondary side of the transformer.yes that's true, however if you are served from a utility pad mounted transformer with multiple taps (no secondary OCPD) the utility in my area for underground runs like a 250al conductors min. so the fault would continue until the primary protection of the xfmr. opens. if that's the case there exist a shock hazard on the meter enclosure? I guess it depends on the size of the xmfr. and the TCC of the primary fuse.
