Ok so I know how we all agree that we don't have to worry about bonding sealtite or flex, when it's not considered an egc. But what about when you encounter an eccentric or concentric KO. Or reducing washers. I know how we like to compare it to bonding PVC. But this is still different. Because if you think about it, if a ground fault did occur within the raceway in question, it still has a metallic core that will become part of the ground fault current path. Electricity doesn't care what the Nec allows. So I think in accordance with 250.4(A)(3) Bonding of electrical equipment. That you would be required to properly bond the raceway in question, under the circumstances stated above. Any thoughts or opinions?
