where equipment is required to have front and rear access (switchboards / switchgear) if you have double the required working space in front of the gear only one entrance / egress door is located in the "front" of the gear outside the working space. the question because the door is on the "front" side of the gear is double working space also required at the back of the gear or is it acceptable to have only 1x working space? (it was my thought that 2x would be required also on the working space behind the gear). just wanted to get your thoughts..
