erickench
- Brooklyn, NY
The above NEC exception states that Metal equipment added to existing knob and tube wiring shall not be required to be connected to the EGC if the metal enclosure is free from contact with ground(or earth). What would happen if the enclosure was in contact with the earth? Does this mean that the earth becomes a fault current path with it's high resistance?
