Would it give you some indication? Thank you.
IMO you would need to be pretty intamte with your solenoid tester to be able to tell the difference between 208, and 240. For that matter if you got 180 one day or 250 the next...I was wondering because it just says on it 120,240,277,480v So since the high leg is between 120-240v. could you tell that your on the high leg.
Ditto, but it shouldn't be too hard with a wiggy.With experience by feel, but I would use a multimeter.
Will a "wiggy" tell you where the high leg is?
