Why do you think a blow gun will work better. BTW Greenlee.com Go there and click on the PDF catalog at the bottom of the page then go to page 12 for the blow gun.yeah, unfortunately a shop vac does not work well with water/ice in underground conduits.
doubt a blow gun would work either.yeah, unfortunately a shop vac does not work well with water/ice in underground conduits.
Yes. And bring MONEY. The good thing about the Greenlee stuff is that they have one hose size for the vac but have adapters that will fit onto the ends of most conduit sizes. OTOH, if you are creative enough you can buy an inexpensive shop vac at Big Orange like Dennis did and make your own adapters. If you buy the Greenlee stuff I'd bet you'll go for about $600.00 + for a complete kit.Try Greenlee.com
Shop vac always worked well for me.
I have used a rotorooter service when the conduit was really jammed up. It beats running a new conduit if it is in a paved road. The worst conduits I have seen are the old orangeburg type. Over time the layers of tar/paper swell and peel off from the inside. This clogs up the pipe pretty good.
I just heard about "Orangeburg" conduit about 2 days ago on a job @ a dam. The engineer I talked to said that they had a hell of a time with pulling fiber through orangeburg that was probably 50 years old. What is it ? EMT? Rigid?
Bituminized fiber drain and sewer pipe (a.k.a. Orangeburg pipe). This type of sewer pipe (2? - 18? diameter) was manufactured as an oval conduit for wiring, etc., from the 1890s to the early 1940s; thereafter, it was made as a round pipe until the 1970s. (There is over 1200 miles of this conduit in the walls and floors of the Empire State Builidng in New York City.) Orangeburg pipe is comprised of cellulose fibers impregnated with hot coaltar pitch. The joints are gasketless. The pipe often softens and deforms with age, allowing infiltration and root intrusion. Two varieties exist: one with solid (homogeneous) walls and one with laminated walls. This pipe material was widely used in house laterals for over 70 years -- until pvc took over.
The Fibre Conduit Company of Orangeburg, N.Y., was a prime manufacturer of this type of pipe. When sewer pipe was first made in the 1940s, they changed their name to the Orangeburg Pipe Co. of Orangeburg, NY.
Source: Larry Vail, Degussa-Hulls Corporation, Allendale, New Jersey.
