ohmhead
- ORLANDO FLA
We used co2 years ago. It would put a mouse through a hollow core door. Might not make it on the safe way to do things today.
Well what is safe today ? Heres what we use
GB still sells compressed air tanks its a complete kit we stopped using that system years ago its way to expensive and a waste of time .
and we used to get are compressed air bottles from a welding supply house these will freeze up the water in the pipe becuse of the pressure in the compressed tank there no good .
They use these everyday in the electrical trade and its safe the high pressure is in the conduit and if you follow the OHSA safety rules on operating a compressor which is you must have a safety release valve on hose at unit air hose input meaning on compressor .
The air hose must be locking type meaning couplings tie wired thur hole type .
If you rent one just tell the company they must have this on unit its theres to install not yours by OSHA .
If for any reason the pressure exceeds a set volume the release valve shuts down unit automatically .
If the hose breaks it shuts down .
The nozzle we use GB sells these for compressors it has a adjustable throttle you start slow and adjust up to suite you needs .
This is a OSHA RULE and they have been on many of our job sites in the past as we were using this system during there walk thur inspection .
When you blast air into a 4 inch conduit all that high pressure gos inside and it fills up the volume of space in that conduit which is not like a 1/2 conduit you have some pressure at first but the when it comes out the other end 600 feet away it just flops out .
Now if you use it on a water filled conduit you get a 25 foot shower on the other end but pressure is not 130 pounds you can put you hand over the end of conduit and feel the minimal air coming out .
Its unsafe if your doing it unsafe .
