- NE Nebraska
- EC
Insn't the guts of a "loadcenter" the actual panelboard and the can is a cabinet? On larger panelboards you usually order a panelboard, main breaker (if needed), feed thru lugs (if needed), and the size and type of cabinet needed as separate items (may or may not be factory assembled but are ordered as separate items).
I once replaced the interior of an old Frank Adams fused switch panel with a QO load center by installing the QO inside the old cabinet. I was lucky the opening on the cover for the fuse panel was exactly the same size as the QO cabinet. Spaced the QO cabinet so that it was flush with this opening and put the QO cover on and removed the FA cover. The thing looked like it was designed for the purpose. It was a whole lot easier than trying to figure out how to replace the whole thing that was mounted flush in a block wall.
