Houston
- I will give you a hint. TX
I have a question? I was told by someone that the bus bar where the breakers clamp onto (the slots) in residential panels are rated only 100 amps. Sorry for the rough description i dont know how to describe this everyday part of the bus.
For instance you cant have a 100 Amp breaker across horizantally from any other breaker because that slot is only rated for 100 amps. Even in a 200 amp panel. I always thought that the bus in a 200amp panel was rated for 200 amps. And as long as you didnt over rate the box it wouldn,t matter.
I also believe the code says somthing about not having the main disconnect across from anything else, having trouble finding that code thou. But the question is for other then main breaker.
I also did some internet research and couldnt find anything. The reason I ask is because I ran into a 125 standard main on the bus. The siemens box had no labeling inside to check. I would like to know if this puts my customer in danger of melting her bus bar.
Thanks
Thanks
