ya thats the problem i had with it too. way too vague. the question was only what do u test coax with?
They're probably not asking you to be too technical, especially if it's multiple choice. A coax cable has a rating in ohms. RG59 is less ohms than RG6. What would you use to take these measurements in ohms?
impedance = (138 / e^(1/2)) * log (D/d)
Where:
* log = logarithm of 10
* d = diameter of center conductor
* D = inner diameter of cable shield
* e = dielectric constant (= 1 for air)
The impedance is 50 or 75 ohms but that is not something that can be easily measured.
A good basic test for coax is center to shield with an ohmmeter to see if its shorted, I suspect that is what they are looking for.
I test coax with a wattmeter, its used with a radio to check the forward power and reverse power. If the reverse power is too high, too much of the transmitter power is being reflected back into the radio and will damage it. A bad or poorly made connector will cause high reflected power. But an ohmmeter will find this. Low reflected power means the system is efficient.
i would use a multi meter to check ohms. If not open or shorted it likely will be ok. That question could be challenged. It lacks what they want you to check it for. a digital or analog can both measure ohms.
At DC, all coax, regardless of impedance rating, will show an open between the center conductor and the shield if all is well.
that would depend on the voltage :grin:
