I don't bend pipe too often, so I was bending 1" and the deduct is 8" for a ninety degree stub. So for a 45 degree, would the deduct be 4" and so on and so on? Thank you for your help.
It actually not a linear ratio, but rather a trigonometric one. The ratio for any bend less than 90? would be the sin of one-half the bend degrees. In the case mentioned, it works out to 3". Note you have to use the deduct value from the tangent point (where the conduit actually starts to bend) as some shoe's "deduct" amount includes a short section of unbent conduit (such as with Greenlee 555's).I don't bend pipe too often, so I was bending 1" and the deduct is 8" for a ninety degree stub. So for a 45 degree, would the deduct be 4" and so on and so on? Thank you for your help.
I don't know about that, but it can still be purchased...Dick Cox really knows how to handle pipe! Sadly that book is no longer in print.
