We installed a NEMA 3R disconnect switch outside next to an existing switchboard with overhead conduits. The new disconnet switch has not be energized. The existing switchboard is hot. We found out that there are a lot of condensate water dripping in the disconnect switch from conduit because hot air from the existing switchboard meet with cold air from disconnect switch then generate condensation water. Have you guys seen this problem before? How did you guys resolve this issue? Thanks.
