It's hard to find a neutral that's truly dedicated. Usually they don't want to go one way or the other. :grin:
It was a poor attempt at a joke.
I don't agree. If you're faithful to yours, they'll be dedicated to you. Mine are.It's hard to find a neutral that's truly dedicated. Usually they don't want to go one way or the other. :grin:
That's impossible to achieve."Circuits supplying line to neutral loads shall have dedicated neutral"
Roger
Unless your house is energized by your own generator...or maybe solar panels?
I believe specifications are not required to use NEC terminology....there is not a "neutral" in a two wire circuit.
I believe specifications are not required to use NEC terminology.![]()
And IMO this is just another case of dumbing down the code for the unqualified.Furthermore, NEC 2008 implemented the "neutral conductor" definition. The specification as written with only the word neutral does imply a "neutral conductor".
