High Voltage and Low voltage
Merry christmas to all,does the NEC allow high voltage and low voltage to be in the same manhole? also if both run under ground what is the minimum distance apart that they should be.
Merry Christmas Everyone Everywhere!
725.136 Separation from Electric Light, Power, Class 1, Non?Power-Limited Fire Alarm Circuit Conductors, and Medium-Power Network-Powered Broadband Communications Cables.
760.136 Separation from Electric Light, Power, Class 1, NPLFA, and Medium-Power Network-Powered Broadband Communications Circuit Conductors.
I agree with Bob.
The NEC does not use the terms "low voltage" and "hing voltage".
What voltages are we talking about?
Chris
High voltage and low voltage
LOW VOLTAGE 50V ac to 1000V ac,HIGH VOLTAGE above 1000V ac .These are voltages between any conductor and earth.
