oscar47
- Destin, fl
Does the NEC have a specific height range for a meter can on a service interence, or, is this specified by the local utility company?
Utility usually says 5.5' from grade to center of socket.Does the NEC have a specific height range for a meter can on a service interence, or, is this specified by the local utility company?
The height of the meter socket is set by the local utility.
Here the height is minimum of 4' to the center of the meter and 6' maximum.
Chris
What do you do if there's a multi gang stack? You're not going to fall in the 4' - 6' realm. I suppose POCO has to take that in consideration. If so, why should they care about narrowing the range for a single meter can?
Well then, that either puts more people out of work, or the remote meter readers will use binoculars.Most POCOs wouldn't care anyway because they're all going to remote-read meters. So even if you put the meter 20' up the side of the building, it wouldn't make a whole lot of difference to them.
Uh , yes it would . Trust me .Most POCOs wouldn't care anyway because they're all going to remote-read meters. So even if you put the meter 20' up the side of the building, it wouldn't make a whole lot of difference to them.
