iwirehouses
I searched every thread here and it seems like there are many perspectives on the correct way to do this.  My previous experience with septics is with ellaborate systems.  The pump installer runs the conduit, wires, and terminations inside the tank.  I walk in, pipe the conduit over the the control panel, terminate the wires, and feed the panel (220, 30A).  I've never been inside the tank doing electrical.   Until now...
This system is a 110 line out to the pump, and a 9v circuit controlling the little dinky alarm which is plugged into an outlet inside. I see theres much debate upon wether or not you can run the 110 an 9v in the same counduit. Also much debate on wether you put a j-box in the tank, or on a post above ground. Can anyone clarrify this?
Would it be easier to run it all in UF? A 12/2 for the 110v pump and a 14/2 for the 9v alarm? That way they're not in the same conduit? I hate using UF. I think conduit is much more professional.
