in-line switch and fuse
electrics
i couldnt understand what does this in-line mean, İs there any fuse or disconnector which is not in-line? can someone explain the gist here...
all the fuses are in-line so why it is needed to describe this??? you mean box of what? can u explain a bit more pls?
excuse me, what i can not understand is why we call them in-line? all the fuses are already in-line arent they? there must be a feature to justify naming them as in-line...
There is no seperate holder or apparatus required.
so u dont need an holder and when fuse blows u screw a new inline fuse?
Typically the inline fuse holder comes apart in the middle by unscrewing it. If the fuse blows you unscrew the holder and insert a new fuse. The advantage is that you don't need the space that a traditional fuse holder requires for mounting.
The "in-line" fuses are the "holder". They are two piece and hold the appropriate fuse. Look at the link.
They just don't "mount"...they are placed in the line similar to a butt connector.
