ohmhead
- ORLANDO FLA
Well i knew you would ask that
With a bias that keeps the waveform either positive or negative.How does a DC output have 47.5Hz?
Now that is a possibility. Up to the point where the phone company notices. I'm not sure what that point is, but it might be interesting to find out (but it probably violates the service agreement).One would be better off stealing electricity from the phone line.
That's about the gyst of it. If I felt froggy I would crunch the numbers to see what you might could drain from different cables at different voltages but I'm in a lazy mode.Looks to me, a simple xfmr circuit.
I think that you would have to keep the load under 20mA so the central office does not see an off-hook condition. It appears as you are permitted to draw small amounts of power for equipment associated with the phone system based on this data sheet.Now that is a possibility. Up to the point where the phone company notices. I'm not sure what that point is, but it might be interesting to find out (but it probably violates the service agreement).
Actually, about 200 hours for 1 kWh.Assuming that this is installed on the load side of the meter, the meter will see the current that is used. How long did they watch the meter? Meters read in KWH and this device would have a load of about 5 watts. What is the resolution of the meter....you would have to leave it on for 20 hours for the meter to read 1 KWH.
This quite amused me:English is not the native language (company is Thai), though I suspect that is not the entire explanation. Check out their website:
http://www.boondee.net/
They also make an electronic ant repellent (maybe the same device as saves electricity), an automatic plant watering device, and a wood lathe.
My favorite quote from website is on the "contact us" page where they give directions on visiting via metro:
Model 1000kw V 1.1 the best of power saver in the market today
You are still adding load to the system and placing it on the line side of the meter is theft of power.
Well we keep on seeing energy saver stuff scams now thisFREE POWER![]()
Its not a power factor device it takes the magnetic field around your wiring in house and makes free power from that but its only good for a low voltage output of 12 volts seems they use your ac power to make dc guess to charge batterys up or led lighting .
:roll:
This appears to be a current transformer, but for that to work, there has to be some load current which would cause the meter disc to spin, and they say that does not happen. Furthermore, the output of the CT would vary with said load. amd the presence of the CT would drop the load voltage somewhat.
Now if they are using capacitive coupling, the output voltage would be essentially constant, but it is hard to believe that they could get enough coupling from a few turns of wire to do anything useful. However if they are doing this, there would be a small extra load in parallel with the main load.
Whatever, it would not be free.
The device may not be worth much but the levels of workmanship and safety measuresures are worth twice as much:Its a waste of time but i just thought you guys would enjoy the lastest invention in our electrical world you cant see it use power because its so small the eye cant see the meter rotate and its a joke .
The plastic version:
http://www.boondeeworkshop.com/8000kw.html
The wood versions:
http://www.boondeeworkshop.com/30000kw.html
http://www.boondeeworkshop.com/800kva.html
The top-of-the-line metal version in showcase condition (no extra charge for the smudges):
http://www.boondeeworkshop.com/1500kva.html
It's all about saving the customer money.Well yes Mivey nice work the only thing i dont like is the breaker on the outside of the nice looking enclosers...
And you can build these in your dining room. The reason we don't have them here is the POCOs and government are working together to keep free electricity from coming to the U.S. Must be a lot of bribery and such going on. The same thing happened with that 100 mpg fuel injection system we all know is out there. It's a conspiracy!I like the 30,000kw version. 30 MW could power a small city. And at 400 volts, no less.
