Arc fault on multi wire circuit
jmshiller
Marco Island
Excuse me for asking what may seem like a simple question, but my experience is mostly commercial and industrial. Need to determine if I can install arc fault breakers on a multi wire circuit, 14/3 romex. Don't see how but would appreciate all comments.
Thanks Jim Shiller
You would need a two pole AFCI breaker.
The only 2 pole AFCI available at this time is made by Siemens. This may or may not work for you.
Sorry, I did install a 2 pole GFIC breaker, however will need to protect 2 circuits of a multi wire circuit with a common neutral.
Thanks for pointing that out.
......? The only DP arc faults I knew of were not the combo type.
The Siemens is.
