jelectroboogie
Hi, i am going to install a 200 a meter disco, for a friend of mine who wants to rent out his basement, i was thinking the best way to do it is set the panel in the basement about 35' away from the meter and run 4/0 al. SE cable inside the house and lb out and into the bottom of the meter disco, which will be my main grounding source now. Run a 2'' rigid up w/ 2/0 cu.for the feeders.
I wanted to set a 200 amp panel inside and set a 100 amp c.b. to feed another 100a panel for the basement, side by side. Then install a emon demon to monitor the 100 amp panel. Both neutrals will be floating. I am in seattle washington, do you think this will pass inspection?
Thanks.
Thanks.
