- Logan, Utah
He says the 'manufacturers instructions' states NOT to plug into a gfci.
Just because the manufacture states to not plug the treadmill into the GFCI does not mean that there might not be a problem with the treadmill itself.
A lot of the time a manufacture will state to not plug their product into a GFCI protected receptacle not because it won't work just fine but because of the specter of "nuisance tripping".
Chris
A treadmill running full-bore with someone huffing away on it, when the power suddenly goes out, is not a pretty sight. The person basically rams him/herself into the control panel at full speed.
So you think this is the reason that the manufacture stated that you can't use the treadmill on a GFCI protected circuit?
Chris
Not quite - there is a third dimension here, which is location. What the combined words of the NEC and then manufacturer add up to is "you cant install this thing in a garage or any othe places where GFCI outlets are fitted".Hmm. A direct conflict between manufacturer and NEC. You cannot do what you must do. What a dilemma.
Are you under the 2008 NEC?
Is this exception a local code?
Chris
It's even more fun to watch when the power comes back on.A treadmill running full-bore with someone huffing away on it, when the power suddenly goes out, is not a pretty sight. The person basically rams him/herself into the control panel at full speed.
I have seen gfci's trip when it was just a 2 prong male cord cap for a L.E.D. work light. Im not sure what was causing it. The gfci would work fine with other tools, such as a drill motor etc..
I couldnt see how any current would leak on the work light since it did not have a ground or metal frame for it to leak through, its plastic. would 'noise' be an issue in this case??
A wholesale major-appliance dealer.What is a freezer outlet?
It is the discount place in the industrial part of town where you can get a meat locker for dirt cheap.What is a freezer outlet?
Never checked the instructions on mine but I know it trips GFCI's.
My question is could it have something to do with static electricity.
Dang, thought I was being so smart and you beat me to it.:grin:
Simple answer for me. Install the receptacle to code. Let the treadmill owner deal with the problem or get out and run on the street like us real runners. :grin:
